RTEMS Logo
RTEMS 4.10.0 On-Line Library
Rate Monotonic Manager Manipulating a Period
19.3.2: Manipulating a Period
The rtems.rate_monotonic_period directive is used to establish and maintain periodic execution utilizing a previously created rate monotonic period. Once initiated by the rtems.rate_monotonic_period directive, the period is said to run until it either expires or is reinitiated. The state of the rate monotonic period results in one of the following scenarios:
