RTEMS Logo
RTEMS 4.10.0 On-Line Library
Rate Monotonic Manager Creating a Rate Monotonic Period
19.3.1: Creating a Rate Monotonic Period
The rtems.rate_monotonic_create directive creates a rate monotonic period which is to be used by the calling task to delineate a period. RTEMS allocates a Period Control Block (PCB) from the PCB free list. This data structure is used by RTEMS to manage the newly created rate monotonic period. RTEMS returns a unique period ID to the application which is used by other rate monotonic manager directives to access this rate monotonic period.
