RTEMS Logo
RTEMS 4.10.0 On-Line Library
Region Manager Adding Memory to a Region
14.3.3: Adding Memory to a Region
The rtems.region_extend directive may be used to add memory to an existing region. The caller specifies the size in bytes and starting address of the memory being added.
NOTE: Please see the release notes or RTEMS source code for information regarding restrictions on the location of the memory being added in relation to memory already in the region.
