RTEMS Logo
RTEMS 4.10.0 On-Line Library
Region Manager Obtaining Region IDs
14.3.2: Obtaining Region IDs
When a region is created, RTEMS generates a unique region ID and assigns it to the created region until it is deleted. The region ID may be obtained by either of two methods. First, as the result of an invocation of the rtems.region_create directive, the region ID is stored in a user provided location. Second, the region ID may be obtained later using the rtems.region_ident directive. The region ID is used by other region manager directives to access this region.
