RTEMS Logo
RTEMS 4.10.0 On-Line Library
Clock Manager Timeouts
7.2.5: Timeouts
Timeouts are a special type of timer automatically created when the timeout option is used on the rtems.message_queue_receive, rtems.event_receive, rtems.semaphore_obtain and rtems.region_get_segment directives. Each task may have one and only one timeout active at a time. When a timeout expires, it unblocks the task with a timeout status code.
