RTEMS Logo
RTEMS 4.10.0 On-Line Library
Clock Manager Delays
7.2.4: Delays
A sleep timer allows a task to delay for a given interval or up until a given time, and then wake and continue execution. This type of timer is created automatically by the rtems.task_wake_after and rtems.task_wake_when directives and, as a result, does not have an RTEMS ID. Once activated, a sleep timer cannot be explicitly deleted. Each task may activate one and only one sleep timer at a time.
