RTEMS Logo
RTEMS 4.10.0 On-Line Library
Interrupt Manager INTERRUPT_DISABLE - Disable Interrupts
6.4.2: INTERRUPT_DISABLE - Disable Interrupts
CALLING SEQUENCE:
function Interrupt_Disable return RTEMS.ISR_Level;
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive disables all maskable interrupts and returns the previous level. A later invocation of the rtems.interrupt_enable directive should be used to restore the interrupt level.
NOTES:
This directive will not cause the calling task to be preempted.
