NOT SUPPORTED FROM Ada BINDING
RTEMS.SUCCESSFUL - ISR established successfully
RTEMS.INVALID_NUMBER - illegal vector number
RTEMS.INVALID_ADDRESS - illegal ISR entry point or invalid old_isr_handler
This directive establishes an interrupt service
routine (ISR) for the specified interrupt vector number. The
new_isr_handler parameter specifies the entry point of the ISR.
The entry point of the previous ISR for the specified vector is
returned in old_isr_handler.
To release an interrupt vector, pass the old handler's address obtained when the vector was first capture.
This directive will not cause the calling task to be preempted.
