RTEMS Logo
RTEMS 4.10.0 On-Line Library
Task Manager Notepad Locations
5.3.8: Notepad Locations
RTEMS provides sixteen notepad locations for each task. Each notepad location may contain a note consisting of four bytes of information. RTEMS provides two directives, rtems.task_set_note and rtems.task_get_note, that enable a user to access and change the notepad locations. The rtems.task_set_note directive enables the user to set a task's notepad entry to a specified note. The rtems.task_get_note directive allows the user to obtain the note contained in any one of the sixteen notepads of a specified task.
