RTEMS Logo
RTEMS 4.10.0 On-Line Library
Task Manager Changing Task Mode
5.3.7: Changing Task Mode
The rtems.task_mode directive is used to obtain or change the current execution mode of the calling task. A task's execution mode is used to enable preemption, timeslicing, ASR processing, and to set the task's interrupt level.
The rtems.task_restart directive resets the mode of a task to its original value.
