RTEMS 4.7.99.2 On-Line Library
Clock Manager clock_getres - Get Clock Resolution
RTEMS POSIX API User's Guide
14.4.3: clock_getres - Get Clock Resolution
CALLING SEQUENCE:
#include <time.h>
int clock_getres(
clockid_t clock_id,
struct timespec *res
STATUS CODES:
On error, this routine returns -1 and sets errno to one of the following:
- EINVAL
The res pointer parameter is invalid.
- EINVAL
The clock_id specified is invalid.
DESCRIPTION:
NOTES:
If res is NULL, then the resolution is not returned.
