RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
Semaphore Manager sem_destroy - Destroy an unnamed semaphore
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
9.4.2: sem_destroy - Destroy an unnamed semaphore
CALLING SEQUENCE:
int sem_destroy(
  sem_t *sem
STATUS CODES:
EINVAL
The value argument exceeds SEM_VALUE_MAX
ENOSYS
The function sem_init is not supported by this implementation
EBUSY
There are currently processes blocked on the semaphore
DESCRIPTION:
The sem_destroy function is used to destroy an unnamed semaphore refered to by "sem". sem_destroy can only be used on a semaphore that was created using sem_init.
NOTES:
If the functions completes successfully, it shall return a value of zero. Otherwise, it shall return a value of -1 and set "errno" to specify the error that occurred.
Multiprocessing is currently not supported in this implementation.
