RTEMS 4.7.99.2 On-Line Library
Files and Directories Manager fchmod - Changes permissions of a file
RTEMS POSIX API User's Guide
4.4.26: fchmod - Changes permissions of a file
CALLING SEQUENCE:
#include <sys/types.h>
#include <sys/stat.h>
int fchmod(
int fildes,
mode_t mode
STATUS CODES:
- EACCES
Search permission is denied for a directory in a file's path prefix.
- EBADF
The descriptor is not valid.
- EFAULT
path points outside your accessible address space.
- EIO
A low-level I/o error occurred while modifying the inode.
- ELOOP
path contains a circular reference
- ENAMETOOLONG
Length of a filename string exceeds PATH_MAX and _POSIX_NO_TRUNC is
in effect.
- ENOENT
A file or directory does no exist.
- ENOMEM
Insufficient kernel memory was avaliable.
- ENOTDIR
A component of the specified pathname was not a directory when a
directory was expected.
- EPERM
The effective UID does not match the owner of the file, and is not
zero
- EROFS
Read-only file system
DESCRIPTION:
The mode of the file given by path or referenced by
filedes is changed.
NOTES:
NONE
