RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
Files and Directories Manager chdir - Changes the current working directory
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
4.4.7: chdir - Changes the current working directory
CALLING SEQUENCE:
#include <unistd.h>
int chdir(
  const char *path
STATUS CODES:
On error, this routine returns -1 and sets errno to one of the following:
EACCES
Search permission is denied for a directory in a file's path prefix.
ENAMETOOLONG
Length of a filename string exceeds PATH_MAX and _POSIX_NO_TRUNC is in effect.
ENOENT
A file or directory does not exist.
ENOTDIR
A component of the specified pathname was not a directory when directory was expected.
DESCRIPTION:
The chdir() function causes the directory named by path to become the current working directory; that is, the starting point for searches of pathnames not beginning with a slash.
If chdir() detects an error, the current working directory is not changed.
NOTES:
NONE
