RTEMS 4.7.99.2 On-Line Library
Process Environment Manager ttyname_r - Reentrant Determine Terminal Device Name
RTEMS POSIX API User's Guide
3.4.21: ttyname_r - Reentrant Determine Terminal Device Name
CALLING SEQUENCE:
int ttyname_r(
int fd,
char *name,
int namesize
STATUS CODES:
This routine returns -1 and sets errno as follows:
- EBADF
If not a valid descriptor for a terminal device.
- EINVAL
If
name is NULL or namesize are insufficient.
DESCRIPTION:
This service the pathname of the terminal device that is open
on the file descriptor fd.
NOTES:
NONE
