  RTEMS POSIX 1003.1 Compliance Guide
ANSI C Section 4.2 --- Diagnostics
assert(), Function, Implemented
ANSI C Section 4.3 --- Character Handling
isalnum(), Function, Implemented isalpha(), Function, Implemented iscntrl(), Function, Implemented isdigit(), Function, Implemented isgraph(), Function, Implemented islower(), Function, Implemented isprint(), Function, Implemented ispunct(), Function, Implemented isspace(), Function, Implemented isupper(), Function, Implemented isxdigit(), Function, Implemented tolower(), Function, Implemented toupper(), Function, Implemented
ANSI C Section 4.4 --- Localization
setlocale(), Function, Implemented
ANSI C Section 4.5 --- Mathematics
acos(), Function, Implemented asin(), Function, Implemented atan(), Function, Implemented atan2(), Function, Implemented cos(), Function, Implemented sin(), Function, Implemented tan(), Function, Implemented cosh(), Function, Implemented sinh(), Function, Implemented tanh(), Function, Implemented exp(), Function, Implemented frexp(), Function, Implemented ldexp(), Function, Implemented log(), Function, Implemented log10(), Function, Implemented modf(), Function, Implemented pow(), Function, Implemented sqrt(), Function, Implemented ceil(), Function, Implemented fabs(), Function, Implemented floor(), Function, Implemented fmod(), Function, Implemented
ANSI C Section 4.6 --- Non-Local Jumps
setjmp(), Function, Implemented longjmp(), Function, Implemented
ANSI C Section 4.9 --- Input/Output
FILE, Type, Implemented clearerr(), Function, Implemented fclose(), Function, Implemented feof(), Function, Implemented ferror(), Function, Implemented fflush(), Function, Implemented fgetc(), Function, Implemented fgets(), Function, Implemented fopen(), Function, Implemented fputc(), Function, Implemented fputs(), Function, Implemented fread(), Function, Implemented freopen(), Function, Implemented fseek(), Function, Implemented ftell(), Function, Implemented fwrite(), Function, Implemented getc(), Function, Implemented getchar(), Function, Implemented gets(), Function, Implemented perror(), Function, Implemented printf(), Function, Implemented fprintf(), Function, Implemented sprintf(), Function, Implemented putc(), Function, Implemented putchar(), Function, Implemented puts(), Function, Implemented remove(), Function, Implemented rewind(), Function, Implemented scanf(), Function, Implemented fscanf(), Function, Implemented sscanf(), Function, Implemented setbuf(), Function, Implemented tmpfile(), Function, Implemented tmpnam(), Function, Implemented ungetc(), Function, Implemented
NOTE: rename is also included in another section.  Rename a File.
ANSI C Section 4.10 --- General Utilities
abs(), Function, Implemented atof(), Function, Implemented atoi(), Function, Implemented atol(), Function, Implemented rand(), Function, Implemented srand(), Function, Implemented calloc(), Function, Implemented free(), Function, Implemented malloc(), Function, Implemented realloc(), Function, Implemented abort(), Function, Implemented exit(), Function, Implemented bsearch(), Function, Implemented qsort(), Function, Implemented
NOTE: getenv is also included in another section.
Environment Access.
ANSI C Section 4.11 --- String Handling
strcpy(), Function, Implemented strncpy(), Function, Implemented strcat(), Function, Implemented strncat(), Function, Implemented strcmp(), Function, Implemented strncmp(), Function, Implemented strchr(), Function, Implemented strcspn(), Function, Implemented strpbrk(), Function, Implemented strrchr(), Function, Implemented strspn(), Function, Implemented strstr(), Function, Implemented strtok(), Function, Implemented strlen(), Function, Implemented
ANSI C Section 4.12 --- Date and Time Handling
asctime(), Function, Implemented ctime(), Function, Implemented gmtime(), Function, Implemented localtime(), Function, Implemented mktime(), Function, Implemented strftime(), Function, Implemented
NOTE: RTEMS has no notion of time zones.
NOTE: time is also included in another section.
Get System Time.
From Surrounding Text
EXIT_SUCCESS, Constant, Implemented EXIT_FAILURE, Constant, Implemented
