  RTEMS POSIX 1003.1 Compliance Guide
pathconf(), Function, Implemented fpathconf(), Function, Implemented _PC_LINK_MAX, Constant, Implemented _PC_MAX_CANON, Constant, Implemented _PC_MAX_INPUT, Constant, Implemented _PC_MAX_INPUT, Constant, Implemented _PC_NAME_MAX, Constant, Implemented _PC_PATH_MAX, Constant, Implemented _PC_PIPE_BUF, Constant, Implemented _PC_ASYNC_IO, Constant, Implemented _PC_CHOWN_RESTRICTED, Constant, Implemented _PC_NO_TRUNC, Constant, Implemented _PC_PRIO_IO, Constant, Implemented _PC_SYNC_IO, Constant, Implemented _PC_VDISABLE, Constant, Implemented
NOTE: The newlib unistd.h and sys/unistd.h are installed and the include search patch is used to get the right one. There are conflicts between the newlib unistd.h and RTEMS' version.
