  RTEMS POSIX 1003.1 Compliance Guide
sysconf(), Function, Dummy Implementation _SC_AIO_LISTIO_MAX, Constant, Implemented _SC_AIO_MAX, Constant, Implemented _SC_AIO_PRIO_DELTA_MAX, Constant, Implemented _SC_ARG_MAX, Constant, Implemented _SC_CHILD_MAX, Constant, Implemented _SC_CLK_TCK, Constant, Implemented CLK_TCK, Constant, Implemented _SC_DELAYTIMER_MAX, Constant, Implemented _SC_GETGR_R_SIZE_MAX, Constant, Implemented _SC_GETPW_R_SIZE_MAX, Constant, Implemented _SC_LOGIN_NAME_MAX, Constant, Implemented _SC_MQ_OPEN_MAX, Constant, Implemented _SC_MQ_PRIO_MAX, Constant, Implemented _SC_NGROUPS_MAX, Constant, Implemented _SC_OPEN_MAX, Constant, Implemented _SC_PAGESIZE, Constant, Implemented _SC_RTSIG_MAX, Constant, Implemented _SC_SEM_NSEMS_MAX, Constant, Implemented _SC_SEM_VALUE_MAX, Constant, Implemented _SC_SIGQUEUE_MAX, Constant, Implemented _SC_STREAM_MAX, Constant, Implemented _SC_THREAD_DESTRUCTOR_ITERATIONS, Constant, Implemented _SC_THREAD_KEYS_MAX, Constant, Implemented _SC_THREAD_STACK_MIN, Constant, Implemented _SC_THREAD_THREADS_MAX, Constant, Implemented _SC_TIMER_MAX, Constant, Implemented _SC_TTY_NAME_MAX, Constant, Implemented _SC_TZNAME_MAX, Constant, Implemented _SC_ASYNCHRONOUS_IO, Constant, Implemented _SC_FSYNC, Constant, Implemented _SC_JOB_CONROL, Constant, Implemented _SC_MAPPED_FILES, Constant, Implemented _SC_MEMLOCK, Constant, Implemented _SC_MEMLOCK_RANGE, Constant, Implemented _SC_MEMORY_PROTECTION, Constant, Implemented _SC_MESSAGE_PASSING, Constant, Implemented _SC_PRIORITIZED_IO, Constant, Implemented _SC_PRIORITY_SCHEDULING, Constant, Unimplemented _SC_REALTIME_SIGNALS, Constant, Implemented _SC_SAVED_IDS, Constant, Implemented _SC_SEMAPHORES, Constant, Implemented _SC_SHARED_MEMORY_OBJECTS, Constant, Implemented _SC_SYNCHRONIZED_IO, Constant, Implemented _SC_TIMERS, Constant, Implemented _SC_THREADS, Constant, Implemented _SC_THREAD_ATTR_STACKADDR, Constant, Implemented _SC_THREAD_ATTR_STACKSIZE, Constant, Implemented _SC_THREAD_PRIORITY_SCHEDULING, Constant, Implemented _SC_THREAD_PRIO_INHERIT, Constant, Implemented _SC_THREAD_PRIO_PROTECT, Constant, Unimplemented _SC_THREAD_PROCESS_SHARED, Constant, Implemented _SC_THREAD_SAFE_FUNCTIONS, Constant, Implemented _SC_VERSION, Constant, Implemented
