  RTEMS POSIX 1003.1 Compliance Guide
CHAR_BIT, Constant, Implemented CHAR_MAX, Constant, Implemented CHAR_MIN, Constant, Implemented INT_MAX, Constant, Implemented INT_MIN, Constant, Implemented LONG_MAX, Constant, Implemented LONG_MIN, Constant, Implemented MB_LEN_MAX, Constant, Implemented SCHAR_MAX, Constant, Implemented SCHAR_MIN, Constant, Implemented SHRT_MAX, Constant, Implemented SHRT_MIN, Constant, Implemented UCHAR_MAX, Constant, Implemented UINT_MAX, Constant, Implemented ULONG_MAX, Constant, Implemented USHRT_MAX, Constant, Implemented
NOTE: These are implemented in GCC's limits.h file.
