RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
Texas Instruments C3x/C4x Specific Information Interrupt Stack
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
9.4.4: Interrupt Stack
RTEMS allocates the interrupt stack from the Workspace Area. The amount of memory allocated for the interrupt stack is determined by the interrupt_stack_size field in the CPU Configuration Table. During the initialization process, RTEMS will install its interrupt stack.
The XXX port of RTEMS supports a software managed dedicated interrupt stack on those CPU models which do not support a separate interrupt stack in hardware.
