RTEMS CPU Architecture Supplement
When passing parameters via registers, the calling convention assumes
that the arguments are placed in particular registers based upon
their position and data type before the subroutine is invoked via
the XXX instruction.
The following pseudo-code illustrates the typical sequence used to call a subroutine with three (3) arguments:
move third argument to XXX move second argument to XXX move first argument to XXX invoke subroutine
With the GNU Compiler Suite, parameter passing via
registers is selected by invoking the compiler with the
-mregparm XXX argument. This argument must be
included when linking the application in order to
ensure that support libraries also compiled assuming
parameter passing via the stack are used. The default
parameter passing mechanism is XXX.
When this parameter passing mecahanism is selected, the XXX
symbol is predefined by the C and C++ compilers
and the XXX symbol is predefined by the assembler.
This behavior is the same for the GNU and Texas Instruments
toolsets. RTEMS uses these predefines to determine how
parameters are passed in to those C3x/C4x specific routines
that were written in assembly language.
