RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
SPARC Specific Information System Reset
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
8.6.1: System Reset
An RTEMS based application is initiated or re-initiated when the SPARC processor is reset. When the SPARC is reset, the processor performs the following actions:
The processor then begins to execute the code at location 0. It is important to note that all fields in the psr are not explicitly set by the above steps and all other registers retain their value from the previous execution mode. This is true even of the Trap Base Register (TBR) whose contents reflect the last trap which occurred before the reset.
