RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
PowerPC Specific Information Vectoring of Interrupt Handler
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
6.4.2: Vectoring of Interrupt Handler
Upon determining that an exception can be taken the PowerPC automatically performs the following actions:
If the interrupt handler was installed as an RTEMS interrupt handler, then upon receipt of the interrupt, the processor passes control to the RTEMS interrupt handler which performs the following actions:
Asynchronous interrupts are ignored while exceptions are disabled. Synchronous interrupts which occur while are disabled result in the CPU being forced into an error mode.
A nested interrupt is processed similarly with the exception that the current stack need not be switched to the interrupt stack.
