RTEMS CPU Architecture Supplement
Each high-level language compiler generates subroutine entry and exit code based upon a set of rules known as the compiler's calling convention. These rules address the following issues:
A compiler's calling convention is of importance when interfacing to subroutines written in another language either assembly or high-level. Even when the high-level language and target processor are the same, different compilers may use different calling conventions. As a result, calling conventions are both processor and compiler dependent.
This section is heavily based on content taken from the
Blackfin uCLinux documentation wiki which is edited
by Analog Devices and Arcturus Networks.
`http://docs.blackfin.uclinux.org/'
