RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
ARM Specific Information Interrupt Processing
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
1.4: Interrupt Processing
  • ARM Specific Information Vectoring of an Interrupt Handler
  • ARM Specific Information Interrupt Levels
  • ARM Specific Information Disabling of Interrupts by RTEMS
  • ARM Specific Information Interrupt Stack
  • Different types of processors respond to the occurrence of an interrupt in its own unique fashion. In addition, each processor type provides a control mechanism to allow for the proper handling of an interrupt. The processor dependent response to the interrupt modifies the current execution state and results in a change in the execution stream. Most processors require that an interrupt handler utilize some special control mechanisms to return to the normal processing stream. Although RTEMS hides many of the processor dependent details of interrupt processing, it is important to understand how the RTEMS interrupt manager is mapped onto the processor's unique architecture. Discussed in this chapter are the ARM's interrupt response and control mechanisms as they pertain to RTEMS.
    The ARM has 7 exception types:
    Of these types, only IRQ and FIQ are handled through RTEMS's interrupt vectoring.
