RTEMS 4.7.99.2 On-Line Library
Stack Bounds Checker stack_checker_report_usage - Report Task Stack Usage
RTEMS Ada User's Guide
25.4.2: stack_checker_report_usage - Report Task Stack Usage
CALLING SEQUENCE:
An Ada interface is not currently available.
STATUS CODES: NONE
DESCRIPTION:
This routine prints a table with the peak stack usage and stack space
allocation of every task in the system.
NOTES:
NONE
