This section defines the Classic API related
system configuration parameters supported by rtems/confdefs.h.
CONFIGURE_MAXIMUM_TASKS is the maximum number of
Classic API tasks that can be concurrently active.
The default for this field is 0.
CONFIGURE_MAXIMUM_TIMERS is the maximum number of
Classic API timers that can be concurrently active.
CONFIGURE_MAXIMUM_SEMAPHORES is the maximum number of
Classic API semaphores that can be concurrently active.
CONFIGURE_MAXIMUM_MESSAGE_QUEUES is the maximum number of
Classic API message queues that can be concurrently active.
CONFIGURE_MAXIMUM_PARTITIONS is the maximum number of
Classic API partitions that can be concurrently active.
CONFIGURE_MAXIMUM_REGIONS is the maximum number of
Classic API regions that can be concurrently active.
CONFIGURE_MAXIMUM_PORTS is the maximum number of
Classic API ports that can be concurrently active.
CONFIGURE_MAXIMUM_PERIODS is the maximum number of
Classic API rate monotonic periods that can be concurrently active.
CONFIGURE_MAXIMUM_USER_EXTENSIONS is the maximum number of
Classic API user extensions that can be concurrently active.
