RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
User Extensions Manager Obtaining Extension Set IDs
22.3.2: Obtaining Extension Set IDs
When an extension set is created, RTEMS generates a unique extension set ID and assigns it to the created extension set until it is deleted. The extension ID may be obtained by either of two methods. First, as the result of an invocation of the rtems.extension_create directive, the extension set ID is stored in a user provided location. Second, the extension set ID may be obtained later using the rtems.extension_ident directive. The extension set ID is used by other directives to manipulate this extension set.
