not currently supported in Ada binding
RTEMS.SUCCESSFUL - period initiated successfully
RTEMS.INVALID_ID - invalid rate monotonic period id
RTEMS.INVALID_ADDRESS - invalid address of statistics
This directive returns statistics information associated with the rate monotonic period id in the following data record:
This directive returns the current statistics information for
the period instance assocaited with id. The information
returned is indicated by the structure above.
This directive will not cause the running task to be preempted.
