RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
Region Manager Deleting a Region
14.3.8: Deleting a Region
A region can be removed from the system and returned to RTEMS with the rtems.region_delete directive. When a region is deleted, its control block is returned to the RNCB free list. A region with segments still allocated is not allowed to be deleted. Any task attempting to do so will be returned an error. As a result of this directive, all tasks blocked waiting to obtain a segment from the region will be readied and returned a status code which indicates that the region was deleted.
