RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
Signal Manager Processing an ASR
12.3.3: Processing an ASR
Asynchronous signals were designed to provide the capability to generate software interrupts. The processing of software interrupts parallels that of hardware interrupts. As a result, the differences between the formats of ASRs and ISRs is limited to the meaning of the single argument passed to an ASR. The ASR should have the following calling sequence and adhere to Ada calling conventions:
procedure User_Routine (
  Signals : in     RTEMS.Signal_Set
When the ASR returns to RTEMS the mode and execution path of the interrupted task (or ASR) is restored to the context prior to entering the ASR.
