RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
Overview Portability
1.7: Portability
The issue of portability was the major factor in the creation of RTEMS. Since RTEMS is designed to isolate the hardware dependencies in the specific board support packages, the real-time application should be easily ported to any other processor. The use of RTEMS allows the development of real-time applications which can be completely independent of a particular microprocessor architecture.
