RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Workarounds for Open Issues in Prototype
PREV UP NEXT Bookshelf RTEMS Remote Debugger Server Specifications
7.8: Workarounds for Open Issues in Prototype
[(I1)]:
Not implemented.We would rather like to work on the formalization of per thread flags and global flags that are much more general than any kludge we could implement,
[(I2)]:
We have tried two solutions in our prototype. The first one was to use the idle thread context contained in the Registers task control block field. The drawback of this solution was that we had to implement specific code for the continue operation immediately following the attach command. We then decided to create a dedicated task that will only exist during the attach phase. This task will call the ``ENTER_RGDB'' exception. This call will execute the Exception Handler that saves a valid context and that notifies a change to GDB. After the first CONTINUE command from GDB, this task will continue its execution and delete itself,
[(I3)]:
As explained above in the synchronization chapter, we choose to serialize events in a way that makes GDB think the system is frozen,
[(I4)]:
As a temporary fix, we have called rtems_task_suspend and used the context switch contex for tasks that are unknown to RGDBSD,
[(I5)]:
Not Implemented yet. If I remember correctly, setting the frame pointer to 0 at task initialization for CISC processor solves this problem (ebp = 0x0 on Intel or a6 = 0x0 on 680x0). This should be done in rtems_task_create function in the path to really starts the task for the first time. The processor/system specific stop condition can be found as macros in the GDB source tree.
