RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
The INITIALIZATION task
PREV UP NEXT Bookshelf RTEMS Remote Debugger Server Specifications
7.1: The INITIALIZATION task
This is the task that must be executed at the boot phase of RTEMS. It initializes the debug context. It must :
If an error occurs at any step of the execution, the connections established before the error will be closed, before the initialization task deletes itself.
