RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
ChorusOs DEC Driver
PREV UP NEXT Bookshelf RTEMS Network Supplement
6.6: ChorusOs DEC Driver
Because ChorusOs is used in several Canon CRF projects, we must provide such a driver on this OS to ensure compatibility between the RTEMS and ChorusOs developments. On ChorusOs, a DEC driver source code already exists but only for a PowerPC target. We plan to port this code (which uses ChorusOs API) on Intel target. This will allow us to have homogeneous developments. Moreover, the port of the development performed with ChorusOs environment to RTEMS environment will be easier for the developers.
