RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Discrete Driver Close a Particular Discrete Bitfield
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
18.5: Close a Particular Discrete Bitfield
This is the driver close call. Usually this call does nothing.
With some drivers, it may be necessary to allocate memory when a particular device is opened. If that is the case, then this is the place where that memory should be deallocated.
