RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Analog Driver Open a Particular Analog
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
17.4: Open a Particular Analog
This is the driver open call. Usually this call does nothing other than validate the minor number.
With some drivers, it may be necessary to allocate memory when a particular device is opened. If that is the case, then this is often the place to do this operation.
