RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
IDE Controller Driver Write IDE Controller Register
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
13.4: Write IDE Controller Register
The ide_controller_write_register routine writes IDE Controller chip register with specified value. IDE Controller chip is selected via the minor number. This routine is not allowed to be called from an application.
void ide_controller_write_register(rtems_device_minor_number minor,
                                   unsigned32 reg, unsigned32 value)
  get IDE Controller chip configuration information from
  IDE_Controller_Table by minor number
  invoke write register routine for the chip
