RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Initialization Code Data Section Recopy
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
7.7: Data Section Recopy
The next initialization part can be found in $BSP340_ROOT/start340/init68340.c. First the Interrupt Vector Table is copied into RAM, then the data section recopy is initiated (_CopyDataClearBSSAndStart in $BSP340_ROOT/start340/startfor340only.s).
This code performs the following actions:
