RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Linker Script Example Linker Command Script
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
4.4: Example Linker Command Script
The GNU linker has a command language to specify the image format. This command language can be quite complicated but most of what is required can be learned by careful examination of a well-documented example. The following is a heavily commented version of the linker script used with the the gen68340 BSP This file can be found at $BSP340_ROOT/startup/linkcmds.
 *  Specify that the output is to be coff-m68k regardless of what the
 *  native object format is.
OUTPUT_FORMAT(coff-m68k)
 *  Set the amount of RAM on the target board.
 *  NOTE: The default may be overridden by passing an argument to ld.
RamSize = DEFINED(RamSize) ? RamSize : 4M;
 *  Set the amount of RAM to be used for the application heap.  Objects
 *  allocated using malloc() come from this area.  Having a tight heap
 *  size is somewhat difficult and multiple attempts to squeeze it may
 *  be needed reducing memory usage is important.  If all objects are
 *  allocated from the heap at system initialization time, this eases
 *  the sizing of the application heap.
 *  NOTE 1: The default may be overridden by passing an argument to ld.
 *  NOTE 2: The TCP/IP stack requires additional memory in the Heap.
 *  NOTE 3: The GNAT/RTEMS run-time requires additional memory in
 *  the Heap.
HeapSize = DEFINED(HeapSize) ? HeapSize : 0x10000;
 *  Set the size of the starting stack used during BSP initialization
 *  until first task switch.  After that point, task stacks allocated
 *  by RTEMS are used.
StackSize = DEFINED(StackSize) ? StackSize : 0x1000;
 *  Starting addresses and length of RAM and ROM.
 *  The addresses must be valid addresses on the board.  The
 *  Chip Selects should be initialized such that the code addresses
 *  are valid.
MEMORY {
    ram : ORIGIN = 0x10000000, LENGTH = 4M
    rom : ORIGIN = 0x01000000, LENGTH = 4M
 *  This is for the network driver.  See the Networking documentation
 *  for more details.
ETHERNET_ADDRESS =
   DEFINED(ETHERNET_ADDRESS) ? ETHERNET_ADDRESS : 0xDEAD12;
 *  The following defines the order in which the sections should go.
 *  It also defines a number of variables which can be used by the
 *  application program.
 *  NOTE: Each variable appears with 1 or 2 leading underscores to
 *        ensure that the variable is accessible from C code with a
 *        single underscore.  Some object formats automatically add
 *        a leading underscore to all C global symbols.
SECTIONS {
   *  Make the RomBase variable available to the application.
  _RamSize = RamSize;
  __RamSize = RamSize;
   *  Boot PROM  - Set the RomBase variable to the start of the ROM.
  rom : {
    _RomBase = .;
    __RomBase = .;
  } >rom
   * Dynamic RAM - set the RamBase variable to the start of the RAM.
  ram : {
    _RamBase = .;
    __RamBase = .;
  } >ram
   *  Text (code) goes into ROM
  .text : {
     *  Create a symbol for each object (.o).
    CREATE_OBJECT_SYMBOLS
     *  Put all the object files code sections here.
    *(.text)
    . = ALIGN (16);      /*  go to a 16-byte boundary */
     *  C++ constructors and destructors
     *  NOTE:  See the CROSSGCC mailing-list FAQ for
     *         more details about the "[......]".
    __CTOR_LIST__ = .;
    __DTOR_END__ = .;
     *  Declares where the .text section ends.
    etext = .;
    _etext = .;
  } >rom
   *  Exception Handler Frame section
  .eh_fram : {
    . = ALIGN (16);
    *(.eh_fram)
  } >ram
   *  GCC Exception section
  .gcc_exc : {
    . = ALIGN (16);
    *(.gcc_exc)
  } >ram
   *  Special variable to let application get to the dual-ported
   *  memory.
  dpram : {
    m340 = .;
    _m340 = .;
    . += (8 * 1024);
  } >ram
   *  Initialized Data section goes in RAM
  .data : {
    copy_start = .;
    *(.data)
    . = ALIGN (16);
    _edata = .;
    copy_end = .;
  } >ram
   *  Uninitialized Data section goes in ROM
  .bss : {
     *  M68K specific: Reserve some room for the Vector Table
     *  (256 vectors of 4 bytes).
    M68Kvec = .;
    _M68Kvec = .;
    . += (256 * 4);
     *  Start of memory to zero out at initialization time.
    clear_start = .;
     *  Put all the object files uninitialized data sections
     *  here.
    *(.bss)
    *(COMMON)
    . = ALIGN (16);
    _end = .;
     *  Start of the Application Heap
    _HeapStart = .;
    __HeapStart = .;
    . += HeapSize;
     *  The Starting Stack goes after the Application Heap.
     *  M68K stack grows down so start at high address.
    . += StackSize;
    . = ALIGN (16);
    stack_init = .;
    clear_end = .;
     *  The RTEMS Executive Workspace goes here.  RTEMS
     *  allocates tasks, stacks, semaphores, etc. from this
     *  memory.
    _WorkspaceBase = .;
    __WorkspaceBase = .;
  } >ram
