RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Region Manager Building an Attribute Set
14.2.2: Building an Attribute Set
In general, an attribute set is built by a bitwise OR of the desired attribute components. The set of valid region attributes is provided in the following table:
Attribute values are specifically designed to be mutually exclusive, therefore bitwise OR and addition operations are equivalent as long as each attribute appears exactly once in the component list. An attribute listed as a default is not required to appear in the attribute list, although it is a good programming practice to specify default attributes. If all defaults are desired, the attribute RTEMS.DEFAULT_ATTRIBUTES should be specified on this call.
This example demonstrates the attribute_set parameter needed to create a region with the task priority waiting queue discipline. The attribute_set parameter to the rtems.region_create directive should be RTEMS.PRIORITY.
