RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Timer Manager Directives
8.4: Directives
  • Timer Manager TIMER_CREATE - Create a timer
  • Timer Manager TIMER_IDENT - Get ID of a timer
  • Timer Manager TIMER_CANCEL - Cancel a timer
  • Timer Manager TIMER_DELETE - Delete a timer
  • Timer Manager TIMER_FIRE_AFTER - Fire timer after interval
  • Timer Manager TIMER_FIRE_WHEN - Fire timer when specified
  • Timer Manager TIMER_INITIATE_SERVER - Initiate server for task-based timers
  • Timer Manager TIMER_SERVER_FIRE_AFTER - Fire task-based timer after interval
  • Timer Manager TIMER_SERVER_FIRE_WHEN - Fire task-based timer when specified
  • Timer Manager TIMER_RESET - Reset an interval timer
  • This section details the timer manager's directives. A subsection is dedicated to each of this manager's directives and describes the calling sequence, related constants, usage, and status codes.
