RTEMS Logo
RTEMS 4.6.0pre5 On-Line Library
Introduction
PREV UP NEXT Bookshelf RTEMS/GDB User's Guide
Chapter 1: Introduction
GDB 4.17 is a source-level symbolic debugger for RTEMS environment. This version is an extension of GNU GDB version 4.17, adapted for the debugging of RTEMS applications in a heterogeneous host-target environment.
This paper documents only the RTEMS/GDB extensions to GNU GDB 4.17, as well as its use in the RTEMS environment. The reader is assumed to be familiar with GNU GDB.
The RTEMS project would like to thank Emmanuel Raguet (raguet@crf.canon.fr) and Eric Valette (valette@crf.canon.fr) of the Canon Research Centre France S.A. for developing and documenting RTEMS/GDB and submitting it.
Copyright © 1988-2003 OAR Corporation
