The network configuration is specified by declaring
and initializing the rtems_bsdnet_config
structure.
struct rtems_bsdnet_config {
* This entry points to the head of the ifconfig chain.
struct rtems_bsdnet_ifconfig *ifconfig;
* This entry should be rtems_bsdnet_do_bootp if BOOTP
* is being used to configure the network, and NULL
* if BOOTP is not being used.
void (*bootp)(void);
* The remaining items can be initialized to 0, in
* which case the default value will be used.
rtems_task_priority network_task_priority; /* 100 */
unsigned long mbuf_bytecount; /* 64 kbytes */
unsigned long mbuf_cluster_bytecount; /* 128 kbytes */
char *hostname; /* BOOTP */
char *domainname; /* BOOTP */
char *gateway; /* BOOTP */
char *log_host; /* BOOTP */
char *name_server[3]; /* BOOTP */
char *ntp_server[3]; /* BOOTP */
The structure entries are described in the following table. If your application uses BOOTP/DHCP to obtain network configuration information and if you are happy with the default values described below, you need to provide only the first two entries in this structure.
void (*bootp)(void)
if your application will use BOOTP/DHCP
to obtain network configuration information.
It should be set to NULL
if your application does not use BOOTP/DHCP.
int network_task_priority
char *hostname
NULL the value
may be obtained from a BOOTP/DHCP server.
char *domainname
char *gateway
129.128.4.1) form.
char *log_host
syslog messages
will be sent.
char *ntp_server[3]
In addition, the following fields in the rtems_bsdnet_ifconfig
are of interest.
Copyright © 1988-2003 OAR Corporation
