RTEMS Logo
RTEMS 4.6.0pre5 On-Line Library
Shared Memory Support Driver
prev UP NEXT Bookshelf BSP and Device Driver Development Guide
Chapter 16: Shared Memory Support Driver
  • Shared Memory Support Driver Shared Memory Configuration Table
  • Shared Memory Support Driver Primitives
  • Shared Memory Support Driver Installing the MPCI ISR
  • The Shared Memory Support Driver is responsible for providing glue routines and configuration information required by the Shared Memory Multiprocessor Communications Interface (MPCI). The Shared Memory Support Driver tailors the portable Shared Memory Driver to a particular target platform.
    This driver is only required in shared memory multiprocessing systems that use the RTEMS mulitprocessing support. For more information on RTEMS multiprocessing capabilities and the MPCI, refer to the Multiprocessing Manager chapter of the RTEMS Application C User's Guide.
    Copyright © 1988-2003 OAR Corporation
