RTEMS Logo
RTEMS 4.6.0pre5 On-Line Library
Non-Volatile Memory Driver
prev UP NEXT Bookshelf BSP and Device Driver Development Guide
Chapter 14: Non-Volatile Memory Driver
  • Non-Volatile Memory Driver Major and Minor Numbers
  • Non-Volatile Memory Driver Non-Volatile Memory Driver Configuration
  • Non-Volatile Memory Driver Initialize the Non-Volatile Memory Driver
  • Non-Volatile Memory Driver Disable Read and Write Handlers
  • Non-Volatile Memory Driver Open a Particular Memory Partition
  • Non-Volatile Memory Driver Close a Particular Memory Partition
  • Non-Volatile Memory Driver Read from a Particular Memory Partition
  • Non-Volatile Memory Driver Write to a Particular Memory Partition
  • Non-Volatile Memory Driver Erase the Non-Volatile Memory Area
  • The Non-Volatile driver is responsible for providing an interface to various types of non-volatile memory. These types of memory include, but are not limited to, Flash, EEPROM, and battery backed RAM. The capabilities provided by this class of device driver are:
    There is currently only one non-volatile device driver included in the RTEMS source tree. The information provided in this chapter is based on drivers developed for applications using RTEMS. It is hoped that this driver model information can form the basis for a standard non-volatile memory driver model that can be supported in future RTEMS distribution.
    Copyright © 1988-2003 OAR Corporation
