BSP and Device Driver Development Guide
This routine is invoked by the "Check Timer" (tmck) test in the
RTEMS Timing Test Suite. It makes the Read_timer
routine NOT subtract the overhead required
to initialize and read the benchmark timer. This is used
by the tmoverhd test to determine the overhead
required to initialize and read the timer.
void Set_find_average_overhead(rtems_boolean find_flag)
disable the subtract overhead feature
The Timer_driver_Find_average_overhead variable is usually
used to indicate the state of the "subtract overhead feature".
Copyright © 1988-2003 OAR Corporation
