BSP and Device Driver Development Guide
This routine is the C main entry point. This is a special routine
and the GNU Compiler Suite treats it as such. The GNU C Compiler
recognizes main() and automatically inserts a call to the
compiler run-time support routine __main() as the first
code executed in main().
The routine __main() initializes the compiler's basic run-time
support library and, most importantly, invokes the C++ global
constructors.
The precise placement of when main() is invoked in the
RTEMS initialization sequence insures that C Library and non-blocking
calls can be made in global C++ constructors.
The shared implementation of this routine is located in the following file:
c/src/lib/libbsp/shared/main.c
In addition to the implicit invocation of __main, this
routine performs some explicit initialization. This routine
sets the variable rtems_progname and initiates
multitasking via a call to the RTEMS directive
rtems_initialize_executive_late. It is important to note
that the executive does not return to this routine until the
RTEMS directive rtems_shutdown_executive is invoked.
The RTEMS initialization procedure is described in the Initialization Manager chapter of the RTEMS Application C User's Guide. Please refer to that manual for more information.
Copyright © 1988-2003 OAR Corporation
