BSP and Device Driver Development Guide
The boot_card() is the first C code invoked. Most of the BSPs
use the same shared version of boot_card() which is located in
the following file:
c/src/lib/libbsp/shared/main.c
The boot_card() routine performs the following functions:
Cpu_table) to a default state,
Configuration) to the BSP's Configuration
Table (variable name BSP_Configuration) so it can be modified
as necessary without copying the original table,
bsp_start(),
rtems_initialize_executive_early()
to initialize the executive, C Library, and all device drivers but
return without initiating multitasking or enabling interrupts,
main() in the same file as
boot_card() which does not return until the
rtems_shutdown_executive directive is called, and
bsp_cleanup() to perform
any necessary board specific shutdown actions.
It is important to note that the executive and much of the
support environment must be initialized before invoking main().
Copyright © 1988-2003 OAR Corporation
