RTEMS Logo
RTEMS 4.6.0pre5 On-Line Library
Target Dependent Files
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
Chapter 2: Target Dependent Files
  • Target Dependent Files CPU Dependent
  • Target Dependent Files Board Dependent
  • Target Dependent Files Peripheral Dependent
  • Target Dependent Files Questions to Ask
  • Target Dependent Files CPU Dependent Executive Files
  • Target Dependent Files CPU Dependent Support Files
  • Target Dependent Files Board Support Package Structure
  • RTEMS has a multi-layered approach to portability. This is done to maximize the amount of software that can be reused. Much of the RTEMS source code can be reused on all RTEMS platforms. Other parts of the executive are specific to hardware in some sense. RTEMS classifies target dependent code based upon its dependencies into one of the following categories.
    Copyright © 1988-2003 OAR Corporation
